My rear is 0-30 minutes neg camber depending on the side, and approx 40 minutes toe in. Thanks for the pictures, I was slightly concerned about the rear toe but looks like yours is pointing quite a bit inwards too.
put washers under two of the wheel bolts, It'll give more cambers and toes.
Love them arms kits. Does Jonlem not make them anymore?
Really love the homemade slide plates. Very god thought, making setup easy.
Looking good Iain
Il just sort you out a Nova shell instead if that's OK.
Seriously though, enough with all the negativity (no pun intended). You can count on one hand the number of Nova's on this site that actually get used on track, those owners generally know what does and doesn't work.
It's slightly more important to get the thrust as low as possible than to get each side perfect front back
