Results 1 to 3 of 3
Thread: * INFO * C20 LET vacuum hose layout
    May 2009
    renfrewshire
    10,167
    Default * INFO * C20 LET vacuum hose layout
    2 diagrams, one if you are plumbing in hot start and tank valve the other if you are not.
    23,816
    This one can be a bit easier...
    User Club Member
    Jan 2007
    brynmawr south wales
    1,223
    On my gt28 set up im running the blue to the actuator and the green ive tapped into the cold side of turbo. The purple is a pipe stright to oil catch tank so what do i do with the open end of amel valve an what do i do with the yellow
