For sale vauxhall nova, unfinished project
3 door Nova 2.0l 16v. No tax or mot
Engine:
Lightened, balanced and knife edged crankshaft with steel h beam con rods and standard forged pistons.
Ported cylinder head matched to manifolds.
Double valve springs.
QED hydraulic high lift cams.
Vernier pulleys
Custom inlet manifold
R1 bike carbs
R1 fuel pump
H&H ignition set up, dizzy amp and coil
Ali radiator
10'' cooling fan
Relocated ali header tank.
Full silicon hose kit
Powder coated rocker and cambelt cover
Recent cambelt, water pump, valve stems ACL race bearings and head set.
Big bore 4 branch exhaust manifold(heat wrapped black)
Custom 2.5 inch stainless exhaust system
Transmission:
Standard f20 gearbox.
Quaife lsd.
Standard LUK clutch.
22 spline driveshafts.
Rosejointed gear linkage
Suspension and steering:
Gaz coil overs.
350lb front springs.
Quaife Quickrack
Corsa c power steering column
Rear strut brace
Body
Fully welded and strengthened engine bay.
Full gte/sr kit
Full respray in VW magic black
Interior
Half leather cupra front seats
Aem wideband gauge
Wheels
Refurbed cav slab wheels
Toyo proxes 195 45 15 tyres with plenty of life
Engine has not been fully ran in yet. Only had a few hours worth of run time so far.
Paint still needs wet sand and machine polish from respray.
Tailgate has some damage however does come with a spare tailgate.
Speedo cable needs replacing as it has snapped. Also speedo/rev cluster needs sourcing.
Wide band/oil temp and pressure Gauges not fully finished.
Car was on the road with tax and mot and driving until recently when the engine rebuild happened
Asking £3000 ono
Any questions please ask. More pics to follow
