Page 5 of 6 FirstFirst ... 3456 LastLast
Results 41 to 50 of 60
Thread: best engine for nova
  1. #41
    Sep 2006
    Nottingham
    1,802
    Or x18xe1/z18xe on bike carbs, I know this is a Corsa,but you'll have more bulkhead room in a Nova.
    https://m.youtube.com/watch?v=5LdwkSYBbKA
  2. #42
    Sexy Beard Face Hobbit's Avatar
    May 2008
    Bristol
    8,036
    Imo what you loose in the corners with a big engine you more than make up for down the straights. Would love to be joined out on track by a small block and be proved wrong though.
    On my budget the most powerful engine i could afford to fit was the V6.
  3. #43
    Senior User Club Member blue_peg_16v's Avatar
    Jun 2007
    doncaster
    8,016
    Let if you like constantly having problems
    xe on carbs for feck all to go wrong running
  4. #44
    Jun 2013
    Cleveland
    436
    Not had a single engine issue with my let in the 3yrs I've owned it and it sees 22psi frequently . Only slight problem was the cts code 15 which turned out to be a corroded loom plug, even for the couple of times I drove it till I found the problem still ran and boosted fine. Compared to some of the engine's I've had over the years the let seems like a master piece in terms of reliability lmao.
  5. #45
    Jan 2003
    SOMERSET
    19,510
    Something will oil pishing out from the sump (stops the rot)
  6. #46
    2,618
    Well Blue peg, about that...
  7. #47
    Club Member Club Member
    stoke
    1,990
    Quote Originally Posted by Edd View Post
    Low comp pistons
    No plate
    No water injection
    No 5th crap
    All on standard management
    Come on then edd. Spill the beans.
    Im building a 1.6 8v turbo myself will use omex manegment. Just want to finish all the odds and ends finished first before I start on the engine itself.
  8. #48
    23,815
    Quote Originally Posted by blue_peg_16v View Post
    Bar needing to make sure it says tuned to run right and i never had a prob with my Let till I messed about with it.
  9. #49
    Jan 2003
    SOMERSET
    19,510
    Quote Originally Posted by Andy View Post
    Decent management rather than manipulating the ecu into thinking the car is stone cold
    Who's does this? !!
  10. #50
    Sep 2008
    Bridgwater
    12,248
    Everybody on here thinks the Courteney conversions did
