crank sensor alwas gives tht when turned off
the rest give clues,the titles?
Get busy with a multimeter
Earth problems? New loom?
you tell us?
like I say you need to have a multimeter out/continuity tester.
Too many on here fit and hope without properly diagnosing faults
I have a plug in the bay that I've tapped up out of the way. Wires are a thick brown and a thick red with white chaser, could they be the problem?
With all those codes (many low voltage ones) i'd be looking at the earths, battery, alternator etc
(┌∩┐(◣_◢)┌∩┐)
Was the live from battery to ecu
Rewired it and the EML went out on first start. Cheers for all your help guys![]()
Good stuff mate.
