Looking good Colin,is the carbon front end really that much longer than a normal nova that you can mount the rad like that ?
Yes, it is a lot longer, I had no idea that was the case until I got it fitted. I guess the guys at UPG in Bulgaria did that deliberately to create more room for there engine install.
Where that flat steel bar is at the front of the subframe is where the clamshell nose comes to.
Loads of extra room then ,easy to duct the air in and out
Will give nice ducy/routing for air flow in too and thought the rad...
I'm now modifying the subframe for the clamshell front, as it was a bit fiddly to get on and off. It will now be more 'quick release';
And I have acquired some new rear calipers, which are lighter (half the weight of the Wilwood go kart calipers), and were very cheap, so I may end up re-doing the rear brakes yet again! These ones came off a Mini hillclimb car, but originate from a GP motorcycle;
But for a little while there will be no progress on this car, as it's about to be put into storage whilst I take delivery of a high-spec. Nova circuit race car. More details on that to follow soon..........so my Nova goes off with standard front suspension and alloys, just to get it rolling;
As per my post about hydraulic clutches in the 'Mechanical' section, I am now searching for a Daewoo gearbox (from a smallblock Daewoo), complete with the clutch slave cylinder, so if anyone can help on that, please let me know. My local breakers yard doesn't have anything.
The White wide arched one by any chance?
Oh no no, I never meant yours. I meant the RWD Zetec one?
