So where did i get too?
Ah yes, the loom needed re routing as i wanted it hidden as poss. So with a huge thanks to Dan for his hard work, he did some fantastic loom re-routing and work for me.... Can't thank you enough.
This was the looms new home. (cover is off)
Comes through here, very very tight. But with a bit of works it sits ok and clears the brake pedal.
Looks tight and is, but clears.
Loom joined to where it needed to be and the car started straight up... Yay.
Now i'm at work at this point (ggrrr) and i get the txt " cars running.... Been a fire... All ok now"
Seems my alt had caught fire! The grounds had melted/rubbed though.
Dan took the alt to bits and rebuilt it from some spares i had....
Refitted, which is a total c***. Had to do it in half and then put back together in the car... Even tho id fitted it before. Bloody things!
All back and running.
Me refitting the front back up. (wing at the time to check front clearance and no it's not 100% finished)
Thanks to Sharon SR for the last two pics... Our 90s car meet....
So car now runs, but is idling a bit lumpy... Reving a bit funny and would stall under load.... Que lots of head scratching.
On to sat, day before the show...
I changed the AFM to see if that helped... No.
So tried a spare ECU... and it fixed it.... We think the alt fire must have damaged the ecu.... So i drove to PVS running PH2.
