Page 262 of 327 FirstFirst ... 162212252260261262263264272312 ... LastLast
Results 2,611 to 2,620 of 3267
  1. #2611
    Nov 2004
    Taunton
    639
  2. #2612
    Jun 2002
    Poole, Dorset, United Kingdom
    8,493
    Quote Originally Posted by stt View Post
    You can get some simple gear indicators from motorbike shops, they self calibrate from revs and speed input
    Good point, I should have remembered those, I had one on my R6 about 15 years ago!
  3. #2613
    Jun 2002
    8,493
    I had a very interesting and long chat with Bill Falconer today regarding the sequential gear lever kit he's developed (see link above to his website).
    It now comes with a gear display panel, and I must say it sounds really promising. All I need now is to find the money to buy it.......
  4. #2614
    Jun 2007
    865
    Does it have to be a dog box Colin
  5. #2615
    Jun 2002
    8,493
    Hi Jezz.
    It will work fine on the synchro 'box, it's just the flat-shift bit which only works with the dog set-up. And obviously you still need to use the clutch with the synchro 'box (unless you want regular rebuilds!).
    Could you get away with a sequential gearshifter in your Class, if the actual gearbox is still a conventional 'H' pattern internally?
  6. #2616
    Jun 2007
    865
    No I am not allowed to use it without going up a class ,I think for me I would be better served saving for a proper sequential ,shame I can't use it though
  7. #2617
    Jun 2002
    8,493
    It seems good value at £1200, there's clearly been a lot of thought and engineering that's gone into the design.
    As always it's a question of prioritising spending, and at the moment I have a knackered LSD to be replaced, which is more important than a different way of shifting gears.
    Small upside today though as I managed to get my 2 damaged split rim wheels repaired for £40 cash. I thought they might end up needing new inner and outer sections, but they did a great job repairing them.
  8. #2618
    Jun 2002
    8,493
    Had a whole day on the car today, so a reasonable amount of progress has been made.
    Temporarily fitted the new (carbon fibre!) oil breather tank;
    Still messing about with the installation of the new pedal box;
    I bought this really nice carbon fibre foot tray/clutch footrest in the hope that it would work, but there's no way it will go in there, which is a huge shame;
    Steering rack now fully installed;
    And starting to make a new switch holder/fuse box;
  9. #2619
    Jun 2002
    8,493
    But most of the day has been spent on putting the engine in. It's not got the correct gearbox on there at the moment, but it's at least in the bay, and allowing me to trial fit the Jenvey's etc;
    Not a lot of clearance round the alternator, but this will be solved when I fit the small, lightweight one I have;
    And the Throttle Bodies, at last.........I was really worried that the roll cage cross brace in the engine bay was going to be a major problem, but luckily I've got away with it;
    The bulkhead needs a little bit of a 'tweak' to allow the air filter and trumpets to sit correctly. This exercise has at least confirmed that I need to use the foam air filter. I had been hoping to use this carbon fibre airbox I had, but there's certainly no room for that...........;
  10. #2620
    leeds
    1,336
    3 Post(s)
    Looks very nice Colin, where did the carbon foot tray come from? Also how much does the catch tank weigh?
