Page 1 of 2 12 LastLast
Results 1 to 10 of 13
Thread: 1.4 MPi conversion! HELP!
    Nov 2011
    Cardigan
    47
    Default 1.4 MPi conversion! HELP!
    Hey guys, this im my nova project, Ive fitted a C14SE head off an astra mk3 on what use to 1.4 carbed engine. Heres what ive done so far, fitted the new head, replaced the crank pully with toothed pully for cranksensor and fitted the cranksensor and connected it up. I am yet to get a fuel pump, but i'll hopefully be able to get it by this weekend. Ive wired up the ecu best i could (feeeble attempt), but still not spark Heres some pictures to show how ive wired it so far, any help would be appreciated:
    The red wire goes to the battery, but i dont know where the black cable goes? i thought was it an earth but on the astra i took it off it went into the thing in the next picture.
    Im pretty sure the black wire went into this.
    Heres the ecu, which i earthed, and the fuel pump relay, correct me if its not the fuel pump relay! And the other black connector went to the fuse box in the astra.
    Anyway, thats what ive done so far, any kind of help would be appreciated! From what i can see ive done everything correct but the wiring!
    Senior User swedge's Avatar
    The local market stall
    5,426
    have a look in the article section for fitting a smallblock xe
    its basicly the same apart from the transponder/immobilisor part as yours dosnt have one
    make sure youyr switched live is live whilst cranking, if not you wont get spark
    Nov 2011
    Cardigan
    47
    Ohh ok thanks :D sorry if i sound stupid but which one is the switched live and how would i check it?
    5,426
    large black is the switched live
    large red to the battery
    thick red blue to the fuel pump
    brown/white and brown/yellow are for flashing the codes cant remember which one goes to the dash, usualy put it on the old choke light so you can flash the codes
    Nov 2011
    Cardigan
    47
    Is the switched wire the black wire in the second pic down? If so is there anywhere on the car where i could connect it to so that when it cranks it has 12v? starter motor? Also just out of curiosity what exactly is the purpose of the switched wire? :D
    5,426
    i took my switched live from the fusebox, i used the wire that goes to the wiper motor im sure its purple just get the volt meter or bulb onto it and make sure you get 12v when cranking the engine
    Nov 2011
    Cardigan
    47
    Ohh sorry mate we replied the same time then! haha Thanks for the reply
    5,426
    i had my ecu bolted to the underside of the battery tray inside the car, the switched live is a feed to the ecu as it needs a permanent live and a switched, if the switched live cuts off when cranking the ecu wont power
    5,426
    also did you get the map sensor which was bolted to the bulkhead of the astra? youll need that for your loom
    Nov 2011
    Cardigan
    47
    Ahhh thanks for all the help! I'll do what you did Ohhhh crap, no i dont think i did take it off. I have two extra connections on the loom, does it connect to one of those?
Tags for this Thread
