Whilst in the local magazine library (tesco) noticed a cool pic of your engine bay in the back of the tv mag. Looks cracking mate.
Yeah that was a nice little surprise.![]()
Working out where the holes where was a lil tricky..
Did it, drilled holes, found out i got the angle wrong so had to re-drill one and slot the other a bit. Green lines are cause i was a little worried the holes where lower than before, but that's cause i have jacked the box up a bit higher too.
Yay all bolted on and holding the box up.
Now because i way over speced the mount there was a bit of trimming need.
But that is good, as i can use the excess as a shoulder for the top hole, as the hole it right center on the weld to the metal is two different heights. (welding it on tomoz in place of the washers)
Now with the mount on, the shaft is... Straight.
Hard to see i know, boot has a kink too which i need to adjust.
Top work Benn![]()
Cheers dude... Cant wait to drive it again...
Nice work Benn
Looks like youve got some grease to clean up tho![]()
Are you still messing around with that mount?!? Jeez.....
Hope you're well mate.
Cheers Ed, yeah i need to get the jet wash out..
Cheers Si, yeah i am. Interest has really been lacking...
Nice shaft.
Old XE track car
Glad you sorted it mate, chroming mounts?
