Satnavi for snakes pass? Start one end, get to end turn around drive back faster... That's what i did.
Useful for corners, scouting overtaking points, actually getting there, getting home, speed camera locations... Sheesh![]()
Sat navs are lighter pace notes than a co driver
well over 50kg weight saving ftw.
Corners???? Look a head!
Well after replacing the plugs x2 and HT leads I think I've found my part throttle bad running! The one hose I reused on the engine, d'oh
Also got myself a Mocal 10 row 230mm oil cooler, opinions on location?
Just need to order some hose up and probably get some push on fittings so I can make them up myself...
Perfect place for the cooler.
Thats whereI was going to put my cooler, unlikely to get damaged and leak! Let me know where you get your hose and fittings, I'll have mine to sort once I get the car up to the house!
Looking good lemon, this car just gets better and better, youre attention to detail is up there with the like of Benn, albeit in a different catergory as you do twiddly bits and Benn polishes them![]()
not enough cable ties holding that cooler in for my liking![]()
Chimp probably get them from ThinkAutomotive or similar. Didn't realise they were so expensive though, I've totalled over £50+VAT on four 90 degree unions and 4m of rubber hose, ouch!
Cheers Spud, I try my best to do a neat job of everything whilst keeping things usable and accessible
Prey, might be a cable tie holding it to the radiator at the bottom for the final finished article![]()
