My rear lights aren't working for the breaks or while the headlights are on, the indicators are working though and so is the reverse light. Any ideas? Thanks
Sounds like an earth problem
Isn't there a switch u set the peddle for the light? Try that
There's a plug going into the break pedal if that's what you mean? I've removed it and plugged it back in but nothing. Earth appears to be fine also.
have you checked the bulbs lmao
Bulbs are fine. Ive managed to get the lights working now but they still dont come on when i break?
Check the earth on the rear panel. Near the boot latch
Or fuses
BRAKE LIGHT SWITCH ANYONE !!!!!!!!!!!! LOCATED JUST ABOVE THE BRAKE PEDAL (CAPS off) (
From the question, I assume the brake lanterns glow when front candles are not lit? But when you light up the fronts, the brake lanterns refuse to glow? Yayse?
If so, earth fault.
That's the brown wire(s).
