what is the spec of the engine
Bit more done today, fuel tank is in, need to sort the fuel lines out, rear beam is now swapped, and I need to put new cables on it, found a slight issue in one of the brake pipes, its been crushed at some point where it goes back on itself under the rear turret so I will need to replace it. Gaz coilovers are on and i put my tail pipe on just to see what it looked like .
Should sit nice when the front is on proper suspension
H27 ODW nova GSI
B333XYP nova hutchinsons cabriolet
Same backbox as mine for the Mk1 I think Cool project fella
Yeah its a gte system but it should work ok
H27 ODW nova GSI
Had another few hours on the car today, trying to sort through some of the wiring that has to hide behind the dash! Also connected the door locks to the pins as they were not connected. Waiting on more parts now before i can do much more but progress is still being made!
These arrived the other day
Will hopefully get the front suspension sorted out over the weekend need to rebuild a couple of drive shafts and sort the gear linkage out as well. The list is never ending it seems
H27 ODW nova GSI
ive a mk1 system on a mk2 aswell, still looks tidy
what wheels you running on this fella?
Havnt decided yet, ive got the choice of 16" soft stars or speedlines
H27 ODW nova GSI
Speedlines on that car, the 02' ish time it wore speedlines first was awesome!
id have to agree with simon.... speedlines ftw
It will most likely end up on speedlines need to buy some tyres for them
H27 ODW nova GSI
