I know i might sound thick , but wot is offset? :oops: All u lot talk about is 45-49 wiv alloys , and at the moment, i am stuck wiv my 13's :o . Please explain, in a sort of idiot guide !!!
Ok i think this is basically correct....
Offset is the distance that the wheel is from the hub in mm, eg Vauxhalls are NORMALLY et49 (et=offset). and Fords are normally et38 (i think) so there is a 11mm difference between the two so if you put a set of ford wheels on your vaux then there would be an 11mm gap so they wont fit correct and would wobble etc etc.
Some companies vary what offset they make there wheels to, eg: Compomotive manufacture wheels with any offset between et00-et49. and so other companies only manufature wheels to one offset, eg:MOMO whos wheels are all et38(i think)
I am pretty sure that Vauxhalls have the highest factory set offset, this why it can get difficult finding wheels although there are enough companies making them now.
Some of this might be wrong but this is what i am led to belive it all means.
hope it helps a little bit, no doubt some of the geeks will explain it better for you if you need it ::
It's the distance (in mm) from the mounting surface, to the center line of the wheel.
thats what i said
i thought subaru's have a higher offset? 50+???
fair enough i hate subaru's with a passion and know sod all about them apart from they are ugleeee and pants :!:
there a bit quick though, gotta give em that
here you go - the ultimate (sort of) offset explanation -
http://www.tirerack.com/wheels/tech/offset.htm
pics n all!
this ones for novas -
http://www.vauxnova.co.uk/WHEELS.htm
so is this one -
http://www.hot-hatch.net/thenova/wheels.html
and this one - top buzz...
http://www.knighta.f9.co.uk/info/offset/offset.htm
and another - check out the pic half way down about how to and not to set yer wheels (and how many novas have sticky out wheels?!!!)
http://www.tyres-online.co.uk/techinfo/alloy.asp
and another - interesting info on loads and camber here...
http://home1.gte.net/macross/offsetFAQ.html
this ones interesting -
http://www.edmunds.com/ownership/tec...8/article.html
wolfraces website faq -
http://www.wolfrace.co.uk/faq.htm
got bored at this point...
(entered uk tyre offset nova into google)
Ade
:o
right no one bother to respond to any questions now Ade has voluntered to do it for us as how can we compete with sh*t like that :!:
Cool.marty did you nick that from PVD's guide in their catalogue?
Matt
