Need to start clearing garage so loads of spare parts:
Rocker cover, needs painting, no baffle plate (x2) ?15 each
Blue injectors ?15
XE dizzy throttle body with TPS (x2) ?15 each
Inlet manfold (x2) ?10 each
Fuel rail (x2) ?10 each
Air flow meter (dizzy type) (x2) ?20 each
XE inlet cam (x2) ?25 each
XE exhaust cam (dizzy) ?20
XE head (non porous but had heavy skim, no exhaust valves) ?25
Pot type flywheel (x2) ?20 each
Starter motor (x2) ?20 each
XE Pistons & rods (2 sets) ?35 a set
Multi rib alternators (x2) ?20 each
Standard LET actuator ?20
LET exhaust manifold only (slight crack in wastegate housing) ?15
Flywheel cover plates ?12
3 bar fuel pressure regulator ?15
SFi box ?10
Dispack intake hose with air temp sensor ?15
Astra GTE standard fuel pump ?15
Calibra oil/volt gauges (front been cut to fit in Corsa) ?25
F16 gearbox (good working order) ?30
Astra GTE front engine mount ?15
Also got another complete XE bottom end i'm stripping if anyone needs anything not listed.
Open to offers on all. All prices plus P&P. No P&P on heavier items like flywheels.
