It's back on a dolly, uncovered and ready to roll out of storage to bring home to work on. Just need to get the S14a into a moveable state so I can get the Neva out!
Please tell me this project will be alive again, 3th time now I went to the thread
Project is still alive! It's now at home so there's hopefully more chance of getting time to work on it, which has happened but I've been distracted with doing some maintenance work on the M3 and then with a new purchase to replace my daily. It's also intended to replace the M3 too but I'm going to try and keep them both as long as I can!
But the Neva work that has happened so far...
I want to get it on the spit so I decided to lop the back end off as it was a) in the way and b) I just wasn't happy with it anyway! I've had some weld in threaded inserts made to go in some tube ends. Next step is to get those in and brackets made from there to the spit ends.
Hopefully some little updates will happen over the summer!
Good to see your still cracking on with this
Good to see it still surviving and hopefully resume progress soon!
This thread should be in a time capsule for others to read, it will one day be history in the making...
So some progress this week which will hopefully continue! Rear bungs now in place and rear part of the spit welded and bolted in the place. The bungs will also act as a mounting point for the rear end structure of the car. Where the back currently is is where the rear screen ends, so can fit in a hatch or saloon body at this point. Fairly happy with the welding considering it has been literally years since I even tacked anything!
On another note, anyone know of any free image hosting sites? Photobucket has the annoying image tags on now grrr....
Tapatalk . No messing around just go onto the png page and post your pics straight on same with all other forums you use all in one place
