ok just read the fault codes of on the ecu from the c20xe they are
21.............tps (throttle position sensor) high voltage
74.............afs (air flow sensor/meter ) high voltage
57.............iscv(idol control valve ) interuption
16.............Knock sensor no change in signal
48.............battery low voltage
31.............Crank sensor no signal
is there something daft that can have caused all these things and by fixing that will resolve them all or are they not linked in any way and the only way of fixing them is bit by bit
any surgestions on how to fix any of the above much apreciated thanks oh and asap please as i want it running tip top asap cheers
