just spent half the day up the garage, theyve got the engine/grbox/suspesion/brakes/driveshafts all connected up!
my front springs were broke, so had to have new one my pads were gone anyway, so had new ones!
problem is, the TB is different so gonna have to use the 1.4 one on the 1.6 inlet as the loom is different, also gona have to use the 1.4 loom as the 1.6 loom isnt in a good condition!
also gona have to use the cam/cam carrier for the dispak, as the other is a dizzy and loom wont fit!
lastly, exhaust dont fit, theres no lambda sensor on the gsi manifold/down pipe, plus, its larger than the 1.4 pipe!
cost what it was meant to be in total when first quoted -
engine ?150
labour ?170
cost so far -
engine ?150
labour ?260
exhaust fabrication ?50
ngk plugs ?12
oil and filter ?11
head gasket set ?7
so im gona have to use the 1.4 fuel pump/ecu/TB/cam carrier/cam/dispack/loom/manifold/downpipe/air box all on the 1.6 bottom end!
what shall i do?
