Page 1 of 3 123 LastLast
Results 1 to 10 of 27
Thread: skimmed heads vs. mechanical timing
    Mar 2008
    SE London
    4,406
    Default skimmed heads vs. mechanical timing
    once a head is skimmed, the leading side of the cambelts going to be loosened right, either upping the chances for a belt slip, or knocking out the timing a touch.
    is this what a vernier pulley is primarily use for ? ... to take up that slack ?
    Feb 2007
    16,486
    yeah it will do.On my grasser engine my old head head been skimmed 1.5mm and as such the belt in the right timing position was flopping about like a soft nob.
    As I couldn't run a vernier pulley (as per class rules) Id have had to run it slightly retarded
    Feb 2007
    16,486
    I have a new head now
    Senior User mowgli's Avatar
    Apr 2002
    35,194
    andy, surely you could move the timing peg slightly......it would be impressive for a scrute to find that
    Apr 2002
    35,194
    Quote Originally Posted by jimbob-mcgrew View Post
    this is one of the reasons I am against skimming for the sake of it.
    unless there is surface damage, then they simply don't need skimming for normal road use.
    in something like andy's competition class, skimming is rife to attempt to get some extra compression & thus extra hp, but it then has its downsides, like the timing being out, then the dizzy timing will be out too & the engine will be a sod to get running bang on unless you start 3d mapping or similar
    Feb 2007
    16,486
    that's why I binned that head.
    what dya mean regarding scrutineering?
    vernier pulleys not allowed but I could run it timed how I please
    Mar 2008
    SE London
    4,406
    i think he means moving the peg behind the pulley to compensate. a custom fix, out of site
    Mar 2008
    SE London
    4,406
    pretty sly mo,
    Apr 2002
    35,194
    it would be tricky to get the peg in the right place, but it would pay with power
  10. #10
    Club Member Club Member dgbnova#1's Avatar
    Nov 2012
    birkenhead
    3,838
    A trick bit of machining could easily see this done only retarding a few mm
    as for the head skimming in that case can you not run thicker or 2 gaskets not that it matters but just a question
    not a fan of skimming I just ask for a pass to check it removing dirt basically
