Results 1 to 10 of 10
Thread: Cheap and cheerful alarm
    Mar 2010
    118
    Default Cheap and cheerful alarm
    Anyone have any suggestions?
    Oct 2009
    aberdeen
    2,892
    You get cheapo ones from places like auto save, usually about £30. Triggered by either the interior light, or current change (ignition) and can be set to go on impact ie hitting the winscreen.
    I personally advise a steering lock, twice this has prevented thieves from getting the cars
    Club Member Club Member dgbnova#1's Avatar
    Nov 2012
    birkenhead
    3,838
    Full wheel cover steering lock a must or snap off wheel don't know about alarms though
    Oct 2009
    aberdeen
    2,892
    Club Member Club Member joff-turbo-nova's Avatar
    Dec 2002
    East Yorkshire ......... Drives : Nova 888
    1,791
    I wouldn't want to skimp too much on security, especially if it has an immobiliser - the last thing you want is being unable to start your car even when the alarm is off !
    Try a budget version of one of the quality companies - here's an example from Cobra ...
    http://www.ebay.co.uk/itm/COBRA-G193...item3a69a547d5
    Top tip - solder ALL your wiring joints - don't use the cheap crimp joiners and wire splicers as it will only cause issues down the line - heat shrink tube all your solder joints, ideally with adhesive lined heat shrink tube.
    I've always used Meta Security products - top quality but a bit pricey .
    Joff
    Work in progress threads
    My Turbo nova :-Link
    Meriva Z20LET project :- Link
    Still not doing standard!
    Senior User mowgli's Avatar
    Apr 2002
    35,194
    wire up a relay like in the pic.....
    'hot' is a 12v feed from the battery
    'load' is to a horn/klaxon etc fitted under the dash
    the switch can then be connected up to the interior light switches, a trembler switch etc... it will make noise until the battery is disconnected.......
    ok, you might want to install a simple time delay circuit & a decent arming switch, but this will make some serious noise and put people off.
    Jul 2012
    Birkenhead, Merseyside
    3,317
    Ive got a oldskool moss alarm here new in box £40 posted and its yours
    Mar 2010
    118
    Do you have a model number I'll have a look?
    Junior User
    Dec 2013
    Dublin
    91
    If you want something you can fit youself falcon do an easy fit alarm has about 4wires,or as above old school moss one
  10. #10
    Mar 2008
    SE London
    4,406
    Quote Originally Posted by samb12 View Post
    a rattlesnake in the footwell
