Ive done the search but was wondering if anyone has overcome the need for aftermarket engine management yet?
I'm sure I heard something about using an astra coupe turbo loom but I might be speaking ****e.
Zlet loom and ecu can be used if you know what you're doing.
You'll need the flyby throttle pedal though
Not for a newbie then?
And hows that going to work?
You can't just change the throttle body to a cable one and expect it to run?
What's the advantage of this over a C20let out of interest?
Cheaper, And more available, probably
ZLEH into a Mk3 astra using Omex management here: http://www.mk3oc.com/forum/showthrea...i-Diary/page74
