Page 1 of 2 12 LastLast
Results 1 to 10 of 17
Thread: final drive diff gears - teeth count
    Mar 2008
    SE London
    4,406
    Default final drive diff gears - teeth count
    im looking into switching diffs.
    does anyone have a pic, or a link, of some sort of chart, with the tooth count of both gears of each ratio ?
    Mar 2008
    SE London
    4,406
    oh and one more thing, ive not done it before, but i understand you can do with the box still in the car.
    pop both shafts out, remove the cover plate, undo the securing latch clip, and then unscrew the big beast castlated nut, then the whole thing comes out ? is that right ?
    what else will i need, just fresh oil and a gasket kit ?
    Sep 2008
    West Yorkshire lad
    22,243
    6 Post(s)
    1 Thread(s)
    I'm sure this will come in handy at one point as you've not mentioned which gearboxes you've looked at.
    Sep 2008
    Bridgwater
    12,248
    Nice little chart that mate +Rep
    Sep 2008
    West Yorkshire lad
    22,243
    6 Post(s)
    1 Thread(s)
    I think I got it off Stuarts Gearbox site a long time ago, cheers though
    Mar 2008
    SE London
    4,406
    thats handy southie
    i was going to put a 4.18 into my f10
    you got any info on tooth count of the diff gears ?
    just so i know what ive got and what im buying, they all look the same
    Oct 2010
    oddthorpe
    507
    Quote Originally Posted by jimbob-mcgrew View Post
    thats handy southie
    just count both input gears teeth and output gears teeth and divide it and thats where the figures in the table are from
    Mar 2008
    SE London
    4,406
    can you explain that a bit more simple for me please pete, i know bugger all about gearboxes.
    the extent of my knowledge is theres 2 gears in the diff that effect the ratio - 1 large and 1 small
    Aug 2006
    I live inside your pants
    4,527
    you will be able to change the crown wheel, but i cant remember if you can get to the pinion without pulling the gear cassette out.
    someone here will know.
    Last edited by meritlover; 05-02-13 at 04:44 PM. Reason: because im a special case.
  10. #10
    Oct 2010
    oddthorpe
    507
    Hi mate , the diff consists of two gears, a large one and a small on the end of your output shaft ,(ignore the planet gears 3xall the same size) count the amount of teeth on the big gear and divide it by the amount on the little gear! this also works on finding the ratios on your gears in the rest of your gearbox I.E. first gear has a input gear (on the input shaft) and a output gear (on the output shaft) count teeth of both gears divide the highest number of teeth with the lowest and the number given is the ratio
    hope this makes sense
