anybody use these.
http://cgi.ebay.com/ebaymotors/JE-Fo...Q5fAccessories
anybody use these.
i dont think you would really save that much. i can see what i can get them for via catcams if wanted? with abit of discount.
dont forget if something was to go wrong, you have to deal with them over in the states rather than over here too. makes life abit easier.
is it the low comp pistons your after? as that pic shows raised crown pistons?
also import tax when arriving in the uk
was looking for pistons with deeper pockets for the valves.im worring about contact with my newman 288 cams fitted.
u should be able to get away with pocketing the stock pistons aslong as there the early forged ones, they would want a further 2mm out in the pockets.
i would say ive got some flat top je pistons, but there for a job but ive not heard off the lad for months. i could get the part number off them though and see what i could do?
aye sounds good let me know.
I have a set if early redtop mahle pistons and rods and are stamped 86p .£50 if you interested.yea my mate had problem when getting stuff from the states he thought he was getting stuff cheap into he got hit with import tax
you got two options if the cams and pistons touch.
Early 86p mahles and have the cutout made bigger. Problem here is you lose compression and squish.
High comp pistons will give more power through higher compression and better squish. The problem here is as and 'insurance' that your money won't be wasted you should get good steel rods like arrow/saenz etc not the cheaper chinese copies (doesn't matter where you buy them from).
Ironically I have a set of Arrows for sale and a set of +1mm paul ivey valves. The only problem with buying them from me and the pistons your indicating is that you'll them want to spec bigger cams to get to 230-250 bhp.... vicious circle.
i aint changing the cams thats for sure they are brand new and were a steal 150 iirc. i will prob go with the early 86p's as i think i have a set. or i might get away with just a set of vernier pulleys i have got it 1 touth out just now to get it turning. cheers for the replies guys i would be stuck without you lot
But cat cams are in Belgium not the Uk? so same issue if something wrong surely?Originally Posted by philip
