i am totally confused now
if i run my fuel pump straight from a battery it runs fine
if i run it from the ecu via the blu/red wire it wont run the pump
if i run it from the battery and check the blue/red wire for voltage i get 14v
the pump is earthed on a spare battery at the moment while i fix this problem
when i run it from the battery i get voltage before my inline fuse on the wire to the battery after the fuse and at the end of the wire
its only when i connect it to the pump i get no voltage
the relay is clicking when it starts but the engine dosnt prime not sure if it should
its a c14xe conversion from a 1.0
