What kind of sealent goes between the cam cover and the head?
Cheers
Sparky
Cheers
Sparky
Or is it a gasket?
Black rtv, use it sparingly though!
what engine?
E16se
Where do I get that from?
any half decent motor factors. if its an 8v engine (too too well up on my engine codes) then there is originally a cork gasket, but its a load of crap
Cam cover, or cam carrier?
Cam cover uses a cork gasket, use a non setting gasket selant like hylomar or similar.
I meant carrier, not up on the terminology.
Personally I'd use the cork gasket from GM, it has a coating on one side. Brush on a thin layer of high temp gasket sealert (so it doesnt ooze out). I dont like Hylomar personally.
I've used Hylomar under the carrier, its OK, but again, high temp gasket sealer is far better. Toolstation do gun sized tube for less than £3.
