Fitted this morning and only seeing 12.08v, anyone see what i've done wrong?
Does the batt light work on the dash
Old XE track car
Yeah it's on
i dont have my haynes to hand but i assume the little blue wire (crap pic) is the charge light wire. if so you need to check youve got a live feed to that when you turn the ignition on
i got 10v across the 2 points
Blue/white wire looks in the wrong place? Check earths
Do you have any better pics? There looks to be another terminal near to the main 12v one, that maybe for the blue/white wire?
IT should be marked D+ IIRC
Old XE track car
Pretty sure there were only 2 connectors, i'll get to the meet then have a look, not like i have a stereo or need lights haha
Will be fine untill the batt dies
does the blue and white wire not need to be on the terminal next to where the thick charging wire is. in the first pic you can see it under the exhaust stud
