Tried to attach the rubber bump strips with double sided trim tape, but they come away after a few days . . . heated them up etc etc
Any ideas on what is good to fix them on??
Best getting decent double sided tape from a motor factors. Mines been on for 24 years so it must be good stuff.
The stuff I have is supposed to be decent and holds the shorter bits ok, but the drivers door strip comes away either on top or bottom strip of tape depending on what mood its in (attached it several times now to try it heated, etc)
Perhaps ill try some different stuff then!
Tiger seal FTW
^^ spoken like a true god ^^Originally Posted by novalicous
ive just done mine with the spongey double sided tape and has held on ok just make sure the strips and the panels are super clean
we use this in work (body shop)
works really good
It looks like the stuff I have - do you heat it before attaching up?Originally Posted by CoolTiger
Try hard as nails double sided tape around £3.99 a reel from b&q :-)
I'm with stupid!Originally Posted by novalicous
(Its a one way deal...they don't come off again )
