looking set of upgraded drive shafts for a corsa xe. was going to use 22 spline ones but dont think they would last
i can get hold of a set with cv's on ready to fit. p.m me if your intrested
use the standard big block shafts off a calibra/cav and get the cav/calibra hubs machined down to fit the corsa bearing's mine was done this way and lasted the lenght of time in which i had the car no probs with loads of hammer cheap as chips too
I ran Astra GTE shafts in my corsa turbo with no probs, used mtech hub flanges though
22 spline shafts with some decent condition CV's will last absolutly fine with an XE.Originally Posted by turbo-boy
22 splines last on a let to.
I have a passengers side shaft from a corsa xe, short one. got cvs and good boots on it pm me an offer if your interested
so wat standard shafts can i use that will just need me to get new flanges or machine the flange of a calibra or cavalier?i hav shafts of a calibra 8v but the long shaft is equal length can i use this set up?
i think you can use calibra/cavalier/astra stuff, just need to change the hubs to suit big block stuff your best off having a look on corsa sport. They like those bubble things there
