is that 3" exhaust not setting you back a bit?
I really don't want to sound rude, but did you run all the new engine components in before even taking it on the rollers? Kid gloves, variable loads & speeds for the first 1000 miles then fresh oil & filter is in order, along with limited revs is best.
What was the oil pressure doing since the build? Where was the heat telling on the rods?
It shouldn't be spinning in 2nd let alone 3rd, even more so as your on a tall 1st and 2nd ?
How did you set the arms up in the end ?
It was run on a bench dyno at Joe Stevens prior to being fitted in the car, this is why I think something has gone tits up as it made something like 260hp there then 197 @ RS Tuning, knowing who mapped it initially I would be very surprised if the map was a issue and even if it was to lose over 60hp from a atmo engine is outrageous
As you say it was all very last minute for you but you certainly want to set those up for the next time out. On 2 of the runs I saw I'd say it wasn't wheel spinning after 1st as the gearing really does seems very tall, it wants a different cwp in there if your just using the one straight out of a F20
