Was there watching you out on track scott car looked and sounded awesome
Was a good day,
Was a good day,
Really, you should of come say hi, worsed bit on that session is i whent for 4th, was unsure if i found it so took it into nutral, then whent back to 3rd for a corner, while doing this i cut back infront of a red pug 205, he was not happy, but these things happen when you dont drive a car all the time...
Sorry dude only seen you by the bridge lined up ready to go on track then on the track it self fair play tho i love your car :) ,,
Took it to shakey today for a thrash, was a good day but no new times as there was a very strong head wind that was dropping everyones times by around 6 tenths of a sec from there normal times etc, so i only got 14.0 s at 99mph quite annoying, but least on a good day i know it will be more consistent at 13.5 s and maybe quicker etc..
PS: there was a red mk2 sr/sri with black Astra mk2 gte wheels there, had png stickers, don't know them/or car?
Not really an update, but as i was at the local tip/waste plant earlier i thought i would enquirer about using the weigh bridge, so turned out i know one of the lads working there so they said yeah any time, so popped over to my mums and then back there to get it weighed.
So.....
880 Kg with driver and just over hath tank (15ltrs?) of fuel etc
Then without me it was 800 Kg and same in tank etc.
So not bad really, they said if i want i can pop back once Ive lightened it more..
Just remembered this site...
And look what came out.
Power at Flywheel (BHP) : 185
Weight without Driver (KG) : 800
Power to Weight Ratio (BHP Per Ton) : 234.96
0 - 60 (Secs) : 5.18
0 - 100 (Secs) : 12.966
0 - 100 (Secs) : 7.77
Quarter Mile (Secs) : 13.60
Terminal Speed (MPH) : 102.44
Drag Strip Quarter Mile (Secs) : 13.40
Drag Strip Terminal Speed (MPH) : 104.34
That is dam dam close! though i have had a 13.5 @ 105 mph..
Who ate all the pie's :)Quote:
pmsl err thats quite light for me, as im sure im around 13.5 but 80kg is more like 12.5?Quote:
Originally Posted by MARTIN KELSON
Awesome! Its great when you can get the real weight and work out your actual BHP/tonne. I've found that LetsTorqueBHP calculator looks quite accurate in the past too.
Half a tank will be more than 15L surely?
At about a kg per litre weight too.
Similar weight to mine.
Well there was say 5ltrs maybe in it, but i put about 12ltrs in it so its all guess work mate.
Iain, I'm happy with that as its so close to my actual PB 1/4 that it must be close IMO.
