Spaceframed SR20DET RWD Nova
So quiet week this week but got 3hrs in this afternoon.
After lots of checking and re-checking that everything was stable and won’t collapse on me, I made a start at removing the remaining sills and floor sections...
https://uploads.tapatalk-cdn.com/202...bc922215ab.jpg
https://uploads.tapatalk-cdn.com/202...f0b1fece80.jpg
https://uploads.tapatalk-cdn.com/202...59be7c7208.jpg
You can now see with the sleeved extensions where the new floor ends up.
https://uploads.tapatalk-cdn.com/202...d945da9a76.jpg
https://uploads.tapatalk-cdn.com/202...b29e8e56ce.jpg
Need to scollop the sleeves around the horizontal tubes for a better fit and to have more of the pillar posts inside the sleeve. Will also make 1 or 2 uprights and a diagonal piece at the rear. Like this...
https://uploads.tapatalk-cdn.com/202...64cecdb44f.jpg
The front will also tie into the front subframe area but will do that when I come to redoing the front chassis rails etc.
Hopefully will get some time for progress evenings this week [emoji4]
So jig done, I started lopping pieces off the front end, first creating room for the footwells.
https://uploads.tapatalk-cdn.com/202...04b62a18de.jpg
And here’s where I’m at as of today. I have the new front half of the floor basic structure in place and the upright tubes which tie in the floor to the turrets (a complicated bit of notching at the top, took a few attempts!). And then to end the day I lopped off the front bar!
https://uploads.tapatalk-cdn.com/202...0cf483dbde.jpg
https://uploads.tapatalk-cdn.com/202...1992d025f0.jpg
https://uploads.tapatalk-cdn.com/202...b1175430dc.jpg
https://uploads.tapatalk-cdn.com/202...5a56a015ee.jpg
https://uploads.tapatalk-cdn.com/202...c9bf3d9549.jpg
https://uploads.tapatalk-cdn.com/202...5c676c06a6.jpg
While I wait on the machined turrets, next step is replacing the box chassis rails with tube with weld in bosses. Bosses should be here this week. I also have to pluck up the courage to chop the current turrets out! I had replacement 90deg bends arrive yesterday ready, along with 5m of tube.
Rockin on!
