mowgli has been at the hob goblin again lol
nobby what i will do is get all the seams wire wheeled back then sort out when you can come do it, i properly wont get much done this week as i down south monday then back up (roll), then back down there again Tuesday and Wednesday so not going to get much done and not to forget its my birds birthday so I'm sure she is going to want to celebrate it at some point (selfish bitch)
what needs cleaning up just the seams in the engine bay or the inner arches aswell?
tj.. i have to drive this evening so no hobgoblin just yet... i have some doom bar that needs using
All the seams you want stitch welding. And any other areas of metal work that need attention.
when i did mine i did the seams on the inner wings and onto where the water bottle sits then down onto where the bottom arm bolts onto and up the sides of the bulkhead and across the bottom of the bulkhead and around the gearshift hole if you get me lol we swapsies for the polycarbs then? plus cups of tea?
yer mate windows (three rear ones) 1 cup of tea or coffee, biscuits and a sandwich (no butter, no bread and no filling)
for the welding
does the dash need to come out?
Sorted, ideally yes but if you lie inside with a damp rag and have a bucket of water to hand or extinguisher no lol What amp is your welder and is it all up and running and have ebough gas and wire etc etc
yours needs taking out so you can sort out the heater matrix anyway.. is the steering wheel undoable? or will you need to borrow my puller??
Ive tried undoing the steering wheel but it doesn't budge, so a puller might be needed mate please and thank you
ive only got a gasless welder but ive got loads of wire for it
while waiting around for work to give me more jobs thought i would have a play about with the engine conversion mount that didn't fit properly :roll:
http://imageshack.us/a/img843/6439/sam1007lv.jpg
spaced it out as it was fouling the timing case
http://imageshack.us/a/img853/7696/sam1015n.jpg
measured how much it was spaced out by so i could redrill the holes for the rubber engine mount
http://imageshack.us/a/img706/6966/sam1016k.jpg
£1 drill bit done the job ;)
http://imageshack.us/a/img266/3433/sam1017u.jpg
1
http://imageshack.us/a/img221/2189/sam1018w.jpg
2
http://imageshack.us/a/img853/373/sam1021yb.jpg
done
http://imageshack.us/a/img708/3714/sam1023w.jpg
much more fun then fitting meters lol
