Too big? [emoji23]
It's starting to take shape...
https://thumbs2.imgbox.com/21/b7/ys7Bk64k_t.jpg
https://thumbs2.imgbox.com/41/1c/4vScoT9s_t.jpg
Just need to make and add these little front pieces next and it's ready for plating in the gaps...
https://thumbs2.imgbox.com/f5/2d/EuUFm9Eh_t.jpg
https://thumbs2.imgbox.com/e7/38/0HsY2AZV_t.jpg
https://thumbs2.imgbox.com/c4/06/xjVV0fW7_t.jpg
I also went to my storage unit today to dig out the shell - not far off test fitting it on the body now! :eek:
Looking good mate
Getting better and better Simps :thumb:
Thanks fellas.
Front turret supports are now in place...
https://uploads.tapatalk-cdn.com/202...9183a4027c.jpg
I’ve also reinstated the front posts for the slam panel & rotisserie mounts, although they will likely change once I’m done with the rotisserie.
Hopefully getting the shell home this week if the weather holds off long enough [emoji1696]
So June 2013 was the first prelim test fit of the engine to see if the project was viable...
https://uploads.tapatalk-cdn.com/202...a62d8c16e4.jpg
Jan 2015 the body was removed from the frame...
https://uploads.tapatalk-cdn.com/202...31a1af418f.jpg
June 2020 and the body is finally reunited with the frame!
https://uploads.tapatalk-cdn.com/202...cb01ebec67.jpg
I’ve now got some fiddling to do to get it in place (about 25mm back and 25mm down. I then want to check clearance of everything (especially the front turrets!) then I can get all the front end welded up.
That's a mile stone right there!
Yeaaahhhhsssss
