Cracked on with the engine work today....
Got all 4 pistons cleaned up and new rings and shells installed and put back into the block...
http://i2.photobucket.com/albums/y15...a/Z18XE035.jpg
New GM oil pump was added as well ...
http://i2.photobucket.com/albums/y15...a/Z18XE034.jpg
Cleaned up the pickup pipe as it was rather cruddy and reinstalled with an new o ring....
http://i2.photobucket.com/albums/y15...a/Z18XE033.jpg
Torqued everything down and then put the sump on with some sealant as these engines don't have a sump gasket....
http://i2.photobucket.com/albums/y15...a/Z18XE036.jpg
Next up was starting on the cylinder head , all 16 valves are rather caked with carbon...
http://i2.photobucket.com/albums/y15...a/Z18XE037.jpg
http://i2.photobucket.com/albums/y15...a/Z18XE038.jpg
This was an inlet valve before.....
http://i2.photobucket.com/albums/y15...a/Z18XE039.jpg
And this is after cleaning .....
http://i2.photobucket.com/albums/y15...a/Z18XE040.jpg
Also thought it would be rude not to get the dremmel out and polish out the ports as they seem to have a very rough casing on the inside, I have left it roughish as I understand these engines work better with the inlet rough, will give the exhaust ports a good going over ....
http://i2.photobucket.com/albums/y15...a/Z18XE041.jpg
Need to finish off the polishing with a longer sanding bit.
Enjoy!
Joff
