Cheers Tom, think I'll go for those Autosprint flat-top pistons too then! Will give you a call/pop over next week :)
Well I blunted my holesaw so progress halted on the cage triangulation - and nowhere local sells a 38mm Bosch holesaw, grr!
So I did a mock engine fitting, and glad I did as it was an utter ballache. Block and box in, finally, after much agro:
http://iainel.co.uk/images/forums/NovaWIP2/793.JPG
You can see it's wonky already though...
http://iainel.co.uk/images/forums/NovaWIP2/794.JPG
Using the middle hole as it fits better this way:
http://iainel.co.uk/images/forums/NovaWIP2/795.JPG
Plenty of room gbox end:
http://iainel.co.uk/images/forums/NovaWIP2/796.JPG
Slightly slotted the rear mount to get it to fit:
http://iainel.co.uk/images/forums/NovaWIP2/797.JPG
Didn't realise the engine sat this high in the bay!
http://iainel.co.uk/images/forums/NovaWIP2/798.JPG
And as suspected, it's wonky as a wonky thing:
http://iainel.co.uk/images/forums/NovaWIP2/799.JPG
Which is going to cause bonnet clearance issues:
http://iainel.co.uk/images/forums/NovaWIP2/800.JPG
I tried dropping it down to the top hole:
http://iainel.co.uk/images/forums/NovaWIP2/801.JPG
Which seems to sit better (maybe a little wonky the other way now?):
http://iainel.co.uk/images/forums/NovaWIP2/802.JPG
But it just didn't go together very nicely, had to force the bracket for the block and it sat like this on the mount:
http://iainel.co.uk/images/forums/NovaWIP2/803.JPG
Because the solid mount's hole is kinda between the original 2 holes, I'm going to modify the bracket so it sits a bit lower:
http://iainel.co.uk/images/forums/NovaWIP2/804.JPG
Trial fit:
http://iainel.co.uk/images/forums/NovaWIP2/805.JPG
Hmm sitting a bit straighter now, but going to file the mount some more. I'll weld up the unused holes and make sure it's nice and strong when I'm happy with it:
http://iainel.co.uk/images/forums/NovaWIP2/806.JPG
