Right as some of you may be aware, my blue nova has now gone to a new home, (i'll let the new owner tell all when he's good and ready!) so i decided to get my ass into gear today and fit my xe in my other nova.
I've used a brian sidebotham (sp?) kit which just consists of an o/sf mount and a spacer for the gearbox. I've never used one of these mounts before, having previously used m-tech stuff, and i'm having a few issues.
I think the engine sits too high in the bay? The bonnet won't shut either. ( i don't really want to hack a piece out) It sits level but i think it's way too high? now this may be down to the fact that i'm using solid tas mounts, but these were used in both my previous cars ( one 1.4, one 2.0) and i never had any probs. The inlet seems unusually tight against the bulkhead, and the nsf mount seems slightly ascew? There's no way that i'm going to get any sort of heater hose on the inlet pipe, even after i've shortened it. I've dropped it out and re mounted it but it's still exactly the same?
If the engine sits any lower though the o/s mount will foul the cambelt covers, and the bottom pulley is about 4mm from fouling the chassis leg as it is now. (admittedly this could be cured with more machining, see pic 2)
Now the other issue is that there's very little room for the inlet bellows to fit, the hose will almost have to be squashed to half it's size to fit it between the camgaurd and strut top. Is this normal? if so how have others done it? silicone hose?
What do we think? does it look ok or am i just being picky/worried Lol!!)![]()
oh and before anybody criticises me for not stitch welding it, that's a job for next winter, for now it needs to be up and runing for mot and pvs!!!
