I'm about to start stripping the underside of my nova to start protecting it for future use. There are a few rust areas where I will cut out and replace with fresh steel. As for the rest there are a quite a few areas of surface rust in the usual places. What are peoples recommendations on products that will last?
I'm thinking
Fully strip underside with wire wheel on a grinder
Cut all rusted areas out and replace with new steel
A good rust converter on all surface rust areas
A good degreasing
Epoxy prime the whole underside
Seam seal all panel joins
Gravitex tinted white
Cavity wax probably dinitrol into wherever possible
I'm hoping to do all this with a brush finish, although I do have access to a small 24L compressor but unsure if its man enough!
Anyone got any views on this as I would like to do this once and for it to last many years to come.
Thanks
