Been cranking my rebuilt 20XE on the starter for quite a while now and the oil pressure light isn't going out.
It's a rebuilt engine, the block and head oil galleries were cleaned out before reassembly.
Before refitting the oil pump I packed the gears with vaseline which I heard was advisable in order to help the pump prime quicker. However I've just removed the oil filter and a lump of vaseline fell out - is there a chance it could actually be blocking the galleries instead of helping? The oil filter itself was full of oil though.
I also removed the bolt on the back of the oil pump and no oil came out of there. I removed the one on the front and some trickled out once I removed the relief valve and spring.
The top end feels very dry if I put my finger in the oil filler cap hole, although the cam lobes have a thin film of oil on but I covered these in oil a week or two ago, so I think it's actually an oil pressure system rather than a faulty sender or gauge.
Help![]()
