ok, this is a nightmare, recently bought my 1.3 SR, been putting unleaded in it, my bro pointed out it should be 4 star, !!!! is this bad!! should i drain it out or get some additive.. please HELP
what year is it mine is e-reg and i use unleaded my mate's is g-reg and he uses four star
Originally Posted by DU NOVA
:?: where you just learning how to use the quote button there or do you have a point?
wasn't sure how to reply.
do u know what i should do bout the gauge ?
all vauc OHC engines are unleaded safe
some of the OHV engines were not but that only covers the 1.0 and a few 1.2's in the likes of old mk1 astras
so u may as well run in on unleaded since its about 8p a litre cheaper
u MAY need the timing setup if the previous owner was running on 4star tho
yep thats right
if it was on unleaded b4 then leave the timing and run on unleaded
if it ran on 4star and u wanna run on unleaded then knock the timing back a bit, otherwise as a safe bet run on optimax as it has a similar RON rating to 4star
unless youve got a cat (which you wont have) it doesnt hurt to stick some LRP fuel (new 4 star) in once in a while.
Unleaded as the name suggests has no lead - which removes one of the helpful (not to the atmosphere mind) lubricants in the engine.
Most engines are adjusted for this but an occasional tank of LRP can help quieten things down a little
Optimax is also excellent for giving the engine a bit more oomph (may need to adjust timing though to see benefits)
Ade
i'm gonna run my 2.0 16v on 105ron carless racing fuel next year :twisted:
the only prolem with LRP and the main reason i wouldnt touch it with a barge pole is its prolly one of the least used fuels in the garage
unleaded and diesel at the top since they are "normal" fuels
super/optimax for folk who what that bit more oomph or with modifided/performance cars
then LRP for really old cars - anyone driving an old car who cant afford anything newer is prolly not gonna give a fuck and chuck the cheaper unleaded in most of the time anyway
so LRP is gonna be lying around in the tanks for much longer than the other varieties
and that cant be good for it
