hi, ive got a 1.0 f reg mk1 nova and i was wondering wats involved in the conversion?? ive got a whole mk1 GTE, is it just swapping everything over or just some bits??
Thanks, James
Thanks, James
Engine, loom, exhaust, fuel lines, fuel tank.
Also need GTE rad/fan.
And a OHC 8v off side engine mount.
Old XE track car
Gearbox too, the 1.0 won't fit the GTE engine...?
"It'll be done when its done"
off side engine mount? Whats different about it?
I'm fitting a GTE engine (eventually) into my project and the offside mount (big metal block with rubber insert) fits into a bracket on the engine bay wall.
How different is it???
Anyone got a pic (and a spare one!)
I've always been told the offside mount is different on the 1L's than OHC engines.
Yeah you'll need gearbox too, but he has a complete gte...
Old XE track car
im 99% sure the 1L mount is different aswell.
you best bet is t undo the shock top mounts, bottom arms, anti-roll bar, engine mounts and gearbox mounts then all you wiring and water pipes an exhaust then the same with the 1L and swop it all over in one go. and you will want the exhaust off the gte aswell which i beleave no1 has mentioned
