Ive been a bit of a lurker around here for 6-8 Months, keeping an eye on things and researching/asking questions.
I have a build planned, when i say planned, its not really started yet, just early stages, but I have gathered a lot of stuff already.
This whole Nova thing started with me buying a complete car off a friend. It was reasonably spec'd.
c14se on 40 webers, a cam (270) and pulley, making 120bhp @ Fly.
Quaife f13 sccr gear kit, 4.5:1 final drive
tran-x diff
quaife quick rack
compomotive mo's
6 point cage
carbin fibre Corbeau seats
Luke harnesses
fibreglass bonnet
spax suspension
solid engine mounts
256 brakes
gsi front bumper
and various other parts.
I have a folder of reciepts for over 10k spent on it, 1900 of that on the bare engine, webers not included.
I paid a reasonable, but fair amount for it knowing the shell was a bit tatty.
Forward on a few weeks and I had a good look around the shell and it was a complete turd, fit only for the scrap yard. So it go stripped of all its good bits and bye bye shell.
I have since sourced a nice clean straight shell. This will be stitch welded, strengthened and lightened.
I have poly windows, fibreglass skinned door and looking in to a fg bootlid.
I also have a fibreglass wide arch kit and skirts to go on.
To compliment that I have a superfwd wide track kit to go on it.
Suspension wise it will be running Bilstein B14 coilovers, eccentric top mounts and a braced rear beam.
Other parts sourced or for sourcing include;
Quaife internal shifter
extended steering column and corsa epas
hydraulic hand brake
floor mounted pedal box
The gearbox is having a 3.933:1 final drive fitted, new genuine synchros and a Quaife ATB diff.
The engine is going to be changed to a z18xe
It will be running z18xer vvt rods, pistons, valves and solid buckets. A decompression plate to get the deck height back to where it should be as the vvt pistons are slightly taller (approx 1.3mm)
A ported head and Piper bp285 cams, piper pulleys, and Piper corsa vxr valve springs.
R1 throttle bodies on a custom manifold, with the intension to run a variable length intake tract.
Emerald management.
Tony Law full exhaust system.
Thats the basics, I will try and set up a photobucket account and get some pics up as and when things happen.
Cheers.
