Results 1 to 5 of 5
Thread: wiring an ignition barrell
    Jul 2013
    Stourbridge
    143
    Default wiring an ignition barrell
    which wire goes where? the car came without an ignition barrell so i haven't got a clue...
    Mar 2008
    SE London
    4,406
    if youve got a multimeter, you can hook the wires to the terminals of the switch, and check for continuity when turning the key to each position.
    from what i can remember, thick red is your constant power from the battery, which provides for the rest.
    thin black is accessories, 1 turn on key
    thick black is ignition, 2nd turn on key
    thick black with red stripe, is starter motor on 3rd turn, which springs back.
    its been an age tho, so i might not be 100% correct with the colours.
    might wanna double check each wire goes where first, or you may pop a fuse.
    Jul 2013
    Stourbridge
    143
    that sounds about right, the two that are hooked together make the dash light up and the black with red stripe starts the car
    Club Member Club Member Plug's Avatar
    Jul 2006
    Dawlish, Devon
    8,672
    You sorted this ? Will try and grab a picture if not
    Formally Known as Gsi_Jimbo, New name No Idea
    my project / my Daily / New track slag project
    Jul 2013
    Stourbridge
    143
    not yet mate
