Due to the layout of my garage I don't have an overly large workbench...
With the vice and pillar drill taking up a fair bit of room I was struggling to find a place for the bench grinder , with only a small amount of space left...
Putting the grinder here would use up the useful space...
And putting it here would mean that the sparks and debris would flick into your face and eyes , not good...
I was considering getting a fancy mechanism they use in kitchens to move kenwood mixers up to worktop level...
But at £130 for the hinge brackets , although a nice solution, it was a cost I could not justify.
So with a little more internet searching and a few head scratching moments I had a brainwave.....
First job was to clear off the bench the vice and pillar drill....
And position the grinder where I wanted it -
you will note that the bench top is made up of 3 wooden planks which was handy. Time to remove the middle one and put in some additional supports...
And then chop the middle board into 3 parts..
Refix the two ends of the planks and ensure that the middle part can reverse...
And then the magic happens - re-attach the vice and pillar drill and all seems to be as it was...
BUT NO .... flip over the middle board and hey presto, one bench grinder...
It sits in the unused space under the bench...
Quite pleased with how it's turned out !
Joff
