Results 1 to 9 of 9
Thread: !!!!!!!!!!!! Urgent Help need!!!!!!!!!!!!!
    Senior Member
    Sep 2003
    Reading
    116
    Default !!!!!!!!!!!! Urgent Help need!!!!!!!!!!!!!
    Is it possible to do the piston rings from under the car (though the sump)?????
    Cause i've just done headgasket, valve steam oil seals, cam, lifters, followers and big end bearing shells and not really want to remove the head again! Its still blowing out blue smoke when booted so i must of damaged piston rings when No3 bearing shell snapped.
    Senior Member
    Jul 2002
    541
    nope not that im aware of its a head off job
    Senior Member
    Sep 2003
    Reading
    116
    Ok mate cheers for that.
    I surpose i could try it any way, can't do to much harm to it if i do i've got a reason to fit a 2.0l turbo.
    Senior Member
    Jan 1970
    Stoke-on-Trent
    3,883
    i think you can but id say its an engine out job!!!
    think the crank would need to come off if there coming out the bottom!!
    Senior Member
    Feb 2003
    616
    u have to take the head off m8, i would just drop the engine out and do it then, be LOT easier, u can get to everything then
    Club Member ade's Avatar
    Mar 2002
    Glasgow Wears:A Skirt
    10,822
    did you allow the engine to be run in before booting it?
    if not it may still smoke/damage new parts...
    or is that an urban myth???
    Senior Member
    Sep 2003
    Reading
    116
    I don't think you have to run seals and gaskets in first.
    But i've just put the engine back in at it was a pain in the arse to do, i ended up being able to select 6 gears out of a 4 speed box some how.
    I also phoned Vauxhall to get price on piston rings and they said they were no longer available and i had to call Clifford Cox (reading)to get them , but i thought the nova shared its engine with the mk1 corsa so they must do them really.
    Senior User mowgli's Avatar
    Apr 2002
    35,194
    reringing a 1.2 is dead easy, but it is a head off/sump off job. might sound daft, but have you cleaned out the breather filter assy, these can sludge up after a lot of use, causing oil leaks, and high crankcase pressure leading to oil blowing out of the exhaust.
    rings are available from loads of places, hunt through the yellow pages.
    Senior Member
    Sep 2003
    Reading
    116
    cheers mowgli, i found out that the piston rings can be done from the sump and i'm losing compression so its defferently piston rings.
    I got a price and for a set it was ?75 at trade discount.
    I know the sump has to come off cause you got to unbolt pistons it was more if i had to take head of but my old boss said no you don't.
    So just a case of saving up to buy the rings!
    No i haven't cleaned out the breather but it works good cause i can feel air coming out when the engine is running.
