Been a bit busy with other matters like the F1 at Silverstone and VBOA Billing, and getting the nova going again (which it is!) .
Anyway spent some time over the weekend finishing off the rear door - seems the rear regulator has been broken twice - there were two bottom tensioners in the bottom of the door ...
The plastic lifter part is a different design - the new one is all plastic - the broken mechanism has a metal sleeve around the lifter....
Anyway got the new mechanism installed and fully working , also took the opportunity to waxoyl the inside of the door....
Repaired the moisture membrane ....
And installed the VXR door card...
Also started refurbing the rear springs....
And rear dampers....
Managed to start replacing the all the brake lines with cunifer - not the straightest of pipes but they aren't going to rust ! Just need to do the other 4 pipes around the car and that's another job sorted!
I have some brake pipe separators coming which will neaten the job up a bit.
Joff
