Got a set of rose jointed tie bar brackets. Comes with 6 lowering plates at 6mm a piece. Would 18-18.5mm be enough to get in the F28?
Also if you know the size of the bolts that come with these that would be very helpful
I used 25mm spacer on the lower arm. Gives me about 5mm clearance...
i believe mine is spaced to around 25mm aswell i will double check later when they get refitted
