hi got my gsi engine running but cant get the heaters 2 blow hot iv check the pipes going in they hot iv put a new thermostat in still nowt
blocked matrix?
is the cable working the hot/cold?
as mowgli says.
is it all the heaters that blow cold or just the centre ones?
is engine up to temperature?
I'm guessing you have sufficient water in system?
head gasket ok?
head ok just been done it gets up to half temp and all the heaters blow cold it did work fine with the 1.2 in
drive it round for 10 mins or so with the cap off
