Page 1 of 13 12311 ... LastLast
Results 1 to 10 of 124
Thread: 1300 first time start up-more problems
    Sep 2008
    Bridgwater
    12,248
    Default 1300 first time start up-more problems
    After sorting a few other problems it still won't start
    -it has fuel injection system now working
    -cam and crank timed correctly
    -no 1 on dizzy cap lined up with rotor arm
    -it has spark when plug placed on exhaust mani
    -oil pressure has come up a bit
    -plugs gapped to 0.6mm
    But still won't start ????
    It has a Kent ast2 cam with adjustable venier wheel, could this be where the problem lies ?
    It has 15 degrees adjustment either way currently set on zero, is this correct ?
    The cap and arm are not genuine, is this going to cause any probs ?
    After 4 days of tinkering with it I fed up now
    I would suspect if I towed it and bumped it if might start but as it has no brakes I can't
    With it being a newly rebuilt engine I'm suspecting this could also be a problem maybe ?
    Any help/ideas/experiences ??? I would really appreciate it
    Edd
    Senior User Club Member
    Apr 2003
    South Wales
    6,566
    If you have spark (and compression!) then it must be fuel related...
    Are you getting fuel to the rail?
    If so, then it should fire - even if teh timing is miles out it will still try and run!
    None of teh above things would stop it running (cam etc)
    Sep 2008
    West Yorkshire lad
    22,243
    6 Post(s)
    1 Thread(s)
    Is anything on this any use for the timing Edd?
    Sep 2008
    Bridgwater
    12,248
    It's got fuel to the rail, took the rail off and fired fuel out of the injectors to check
    I've not checked the compression tbh as I would think that is fine, maybe the next thing to check, engine was rebuilt before me putting it in
    Sep 2008
    Bridgwater
    12,248
    Possibly Southie, can't read that on my iPhone tho have to wait till I get home at 7pm and use PC
    Sep 2008
    West Yorkshire lad
    22,243
    6 Post(s)
    1 Thread(s)
    Here are the timing figures for your cam: 36/74 74/36
    and inlet timing at full lift: 109 degrees
    Sep 2008
    Bridgwater
    12,248
    That will be of some use mate cheers
    Going to pick up a compression tester after work but I can't think that is the problem tbh it seems timing related now
    Club Member Club Member Plug's Avatar
    Jul 2006
    Dawlish, Devon
    8,672
    is there fuel getting into the chambers? maybe the injectors dont work?
    Just an idea
    Formally Known as Gsi_Jimbo, New name No Idea
    my project / my Daily / New track slag project
    Senior User mowgli's Avatar
    Apr 2002
    35,194
    have you put brand new plugs in it?
    or tried easystart down the intake to see if the electrics work?
  10. #10
    Sep 2008
    Bridgwater
    12,248
    The injectors work I've fired fuel out of them
    I've tried a new set of plugs as well
    I havnt tried Easy Start tbh, that going to make much of a difference ?
