Results 1 to 7 of 7
Thread: c20xe crank end cap?
    May 2009
    stourbridge
    834
    Default c20xe crank end cap?
    hi all, the end cap that bolts the crank in, what sealant do you use to 'seal' it , shown in picture where, also is it only the big crank seal that goes in there when its put back together? and is 60 lb of torque ok for the arp mains? cheers
    Feb 2007
    Kent
    1,069
    Vauxhall ATV Sealant, awsome stuff, you need a mastic gun thingy for the tube...
    just the seal yes, be carefull not to pinch it, i normally put a little bit of grease on the inside lip "crank face"
    I never knew ARP made mains bolts >?, whats the part number ?
    Standard Mains Bolts are..
    Oil the threads, ikle bit of graphite grease under head,
    Stage 1 - 37LB/FT ~ 50NM
    Stage 2 - 40DEG - 50 DEG
    Banned
    Jan 2006
    Hull, drives: The Wife's Celica, Fixes: Mates cars, Saves: for A16VTB
    11,720
    tap the seal home after youve fitted the cap, or it wont seal properly.
    May 2009
    stourbridge
    834
    thanks for info lads, will go to vaux 2moz and get some, link 2 the mains skidmarkz:
    http://cgi.ebay.co.uk/Vauxhall-Opel-...3A1%7C294%3A50
    Feb 2007
    Kent
    1,069
    Quote Originally Posted by yayoboy
    Ta
    Just popped down the garage the atv part number is below mate,
    PN: 93165267
    i also use it to seal the sump gasket at the oil pump joins, awsome stuff
    Feb 2007
    Kent
    1,069
    http://www.arp-bolts.com/Catalog/Catalog.html
    check this out, it has the information on the stud kit u have
    page 43-44
    May 2009
    stourbridge
    834
    cheers m8
