what anyone think of those subs? obviously i gather the kicker be better but its expensive . what do people think? also does anyone know why a system sounds much louder and more bassy in a fiesta than a nova?
Meh, they're both budget, go with whichever.
What amp do you have?
"It'll be done when its done"
jbl grand touring amp. got a 12" pioneer atm but fancy a 15" now.
Specs on amp, and both subs? Resistance, channels/coils, RMS, PMPO, etc.
ill find em now
if you listen to fast bassy music i would just get a better 12" sub tbh
15" are ok if you listen to slow bass
FLI Size: 15" (397mm)
RMS Power: 400W
Peak Power: 1200W
Sensitivity: 90dB
Frequency Response: 20Hz - 850 Hz
Mounting Diameter: 350mm
Mounting Depth: 148mm
Voice Coil: 2" aluminium, 2 layer.
Overall Max Frequency Response:
500 Hz
KICKER
<LI class=highlight>Overall Min Frequency Response:
25 Hz
General Features:
Heat-Resistant Voice Coil, Vented Pole Piece
<LI class=highlight>Sensitivity:
90.2 dB
Cone Material:
Polymineral
<LI class=highlight>Peak Power Output:
500 W
Magnet Weight:
75 oz
<LI class=highlight>Diameter:
15 in
Mounting Depth:
7.38 in
<LI class=highlight>Nominal Impedance:
4 ohm(s)
RMS Power Output:
250 W.
the amp is 2 channel 500 watt max, 200 rms. it really makes the subs i have ran off it boom
and i listen to slow bass, hip hop mainly. not often dance music
The FLI is better suited to that amp, assuming the amp is 200WRMS @ 4Ohm. Its underpowered for the Kicker one.
The specs on the Kicker are more realistic though, instead of marketing figures like the FLI has...
thanks mate +rep
